Hi Team Support,
how to show the detail of CPU,memory,fan,temperature,etc on Nagiso XI if the device are like Juiper,Cisco,F5 ?
please help me.
CPU,Memory on Network Device
Re: CPU,Memory on Network Device
For the Cisco/Juniper devices, you would probably need to refer to their manuals to get the specific OID/MIB to run an snmp query against. Then, once you know that value, you could set it up as a check using check_snmp.
If you're not incredibly familiar with SNMP, you could share an snmpwalk against the device here and we could probably identify the relevant MIBs/OIDs.
Hi Support,
I have tested oid with adding network device e.g Firewall juniper ssg 520 but still error with error message "No response ....."
i have tried ssh with ip address 161 is working
the oid is here
.1.3.6.1.4.1.3224.16.1.1.0 cpu
.1.3.6.1.4.1.3224.16.2.1.0 memory
please assist me.
the oid is here
please assist me.
Can you share the output of an snmpwalk from your Nagios XI machine against the respective branches? Like so replacing the arguments with ones appropriate for your device:
Some other branches I would like to see the output for:
Here's a sample output for one of the HOST-RESOURCES-MIB trees on one of my lab machines:
Though yours will look very different.
snmpwalk -mALL -v<version> -c<community> <host> 1.3.6.1.4.1.3224.16.4.1Code: Select all
1.3.6.1.4.1.3224.16.3Code: Select all
[root@xi-stable ~]# snmpwalk -mALL -v2c -cwelcome2 192.168.67.105 1.3.6.1.2.1.25.2.3.1.3
HOST-RESOURCES-MIB::hrStorageDescr.1 = STRING: Physical memory
HOST-RESOURCES-MIB::hrStorageDescr.3 = STRING: Virtual memory
HOST-RESOURCES-MIB::hrStorageDescr.6 = STRING: Memory buffers
HOST-RESOURCES-MIB::hrStorageDescr.7 = STRING: Cached memory
HOST-RESOURCES-MIB::hrStorageDescr.8 = STRING: Shared memory
HOST-RESOURCES-MIB::hrStorageDescr.10 = STRING: Swap space
HOST-RESOURCES-MIB::hrStorageDescr.31 = STRING: /
HOST-RESOURCES-MIB::hrStorageDescr.36 = STRING: /dev/shm
HOST-RESOURCES-MIB::hrStorageDescr.38 = STRING: /run
HOST-RESOURCES-MIB::hrStorageDescr.39 = STRING: /sys/fs/cgroup
HOST-RESOURCES-MIB::hrStorageDescr.57 = STRING: /bootFormer Nagios employee
