Team,
I have added new instance to my existing instance. Both instances are logging successfully and instatus status is also in green. But my instance overview shows not running even though the system is fine. Can you help me on this?
Instance overview
Instance overview
Re: Instance overview
From both instances what is the output of service logstash status and service elasticsearch status?
Please find the outputs
As long as you're able to verify that both Logstash and Elasticsearch are running from the CLI, you can disregard the red ! in the GUI. This is a known issue (bug ID 10961) with certain environments that can be caused by a few different things. The developers are aware of the bug and are working on a solution.
Thank you. You can close this post
