define timeperiod{
timeperiod_name weekly-maintenance
alias Weekly Maintenance Windows
sunday 00:00-04:29,04:45-00:00
monday 00:00-04:29,04:45-00:00
tuesday 00:00-04:29,04:45-00:00
wednesday 00:00-04:29,04:45-00:00
thursday 00:00-04:29,04:45-00:00
friday 00:00-04:29,04:45-00:00
}Code: Select all
name CRM-Service ; The 'name' of this service template
active_checks_enabled 1 ; Active service checks are enabled
passive_checks_enabled 1 ; Passive service checks are enabled/accepted
parallelize_check 1 ; Active service checks should be parallelized (disabling this can lead to major performance problems)
obsess_over_service 1 ; We should obsess over this service (if necessary)
check_freshness 0 ; Default is to NOT check service 'freshness'
notifications_enabled 1 ; Service notifications are enabled
event_handler_enabled 1 ; Service event handler is enabled
flap_detection_enabled 1 ; Flap detection is enabled
failure_prediction_enabled 1 ; Failure prediction is enabled
process_perf_data 1 ; Process performance data
retain_status_information 1 ; Retain status information across program restarts
retain_nonstatus_information 1 ; Retain non-status information across program restarts
is_volatile 0 ; The service is not volatile
check_period 24x7 ; The service can be checked at any time of the day
max_check_attempts 3 ; Re-check the service up to 3 times in order to determine its final (hard) state
normal_check_interval 2 ; Check the service every 10 minutes under normal conditions
retry_check_interval 1 ; Re-check the service every two minutes until a hard state can be determined
contact_groups CRMadmins ; Notifications get sent out to everyone in the 'admins' group
notification_options w,u,f,c,r ; Send notifications about warning, unknown, critical, and recovery events
notification_interval 5 ; Re-notify about service problems every hour
notification_period weekly-maintenance ; Notifications can be sent out at any time
register 0 ; DONT REGISTER THIS DEFINITION - ITS NOT A REAL SERVICE, JUST A TEMPLATE!
}we are not getting alert E-Mails or recovery emails even after completing the scheduled downtime which is 4:30 to 4:45.
is any change required in my current setup ?
