NCPA 2.0.2 plugin returns incorrect stdout
corkyman
Post by corkyman »
I am testing the new NCPA 2.0.2 agent and created a test plugin test.bat that echoes the supplied argument.
Under NCPA 1.8.1 the plugin returns {
"value": {
"returncode": 0,
"stdout": "hello"
Under NCPA 2.0.2 the plugin returns
"returncode": 0,
"stdout": "ECHO is off."
Please see the attached screen print.
Re: NCPA 2.0.2 plugin returns incorrect stdout
Post by mcapra »
Arguments for scripts are being changed for 2.1.0 to work a little bit better. See this github issue (and feel free to chime in if you like):
https://github.com/NagiosEnterprises/ncpa/issues/316
I was able to replicate this behavior consistently on my Windows machine.
corkyman
Post by corkyman »
It does not feel like these problems are related. I updated the plugin not to require an argument (so no slashes) and got the same result. Please see attached.
What is the plugin's version that you are currently using? You can view it by running the following command from the command line:
/usr/local/nagios/libexec/check_ncpa.py -V
I haven't been able to recreate the issue (I am running NCPA agent 2.0.3). Here's what I tried:
1st test (without passing arguments)
test.bat
@echo off
echo hello
In the GUI:
2nd test (with passing one argument)
test2.bat
@echo off
echo %1
In the GUI:
I have tried both, the "new" API endpoint (plugins), and the "old" (deprecated) API endpoint (agent/plugin). Both seemed to work just fine for me:
Examples:
https://192.168.x.x:5693/api/plugins/test.bat
https://192.168.x.x:5693/api/plugins/test2.bat
https://192.168.x.x:5693/api/agent/plugin/test.bat
https://192.168.x.x:5693/api/agent/plugin/test2.bat
corkyman
Post by corkyman »
I am not using the check_ncpa.py. Executing the test.bat plugin through the browser interface. I will load 2.0.3 and recheck.
corkyman
Post by corkyman »
Could you run your https execution examples in the browser instead of a GUI and include the argument? I think you will be able to reproduce the problem using the deprecated API format.
I tested 2.0.3 and see that
1. Running the test.bat plugin without arguments works with an old API format (it did not in 2.0.2)
2. Running test.bat plugin with an argument works using the new API format.
3. Running test.bat with an argument using old API format does not work. I believe it is the same error as mentioned at the beginning of this incident--parsing of slashes.
NCPA has problem recognizing that /hello is an argument and tries to download it, then creates a 'hello' file. Please see the screen prints.
Actually, you are correct. The second time I tried this, I was able to recreate the issue. Having said that, "agent/plugin" will be removed soon in favor of "plugins", so that shouldn't be an issue. You are however welcome to file a bug report (if you wish) here:
corkyman
Post by corkyman »
Well, I wish there was an easier way to make a bug report out of this incident. I will make it an awareness item for myself and my group instead. Please close this incident. Thank you for your help.
