Nagios XI database issue " myisamchk: error"
anish
Post by anish »
We are facing issue at database end after upgrading nagios xi from 5.3.2 to 5.4.1.
After running DB repair script, we get below error:
myisamchk: error: 'xi_sysstat.MYI' is not a MyISAM-table
myisamchk: error: 'xi_meta.MYI' is not a MyISAM-table
myisamchk: error: 'xi_events.MYI' is not a MyISAM-table
Kindly provide your assistance.
Regards,
Rohit Tiwari
Re: Nagios XI database issue " myisamchk: error"
Post by mcapra »
Was this database modified after you initially installed Nagios XI?
Can you share the output of the following command executed from the CLI of your Nagios XI machine:
echo 'SELECT TABLE_NAME, ENGINE FROM information_schema.TABLES WHERE TABLE_SCHEMA = "nagiosxi";' | mysql -uroot -pnagiosxi
anish
Post by anish »
Issue has been resolved..
we restored the db backup to resolve the issue.
However we are not sure what caused the issue. After 5 days of upgrade.
Post by mcapra »
The default MySQL storage engine did change from MyISAM to InnoDB at some point, though I don't think the upgrade scripts for Nagios XI's tables would do that. The only other thing that might have caused it is if the tables where altered by hand.
