check_snmp - Cannot create temporary filename
Post by Box293 »
Recently I upgraded to nagios-plugins 1.4.15 on my test box. I wanted to do this so I could try out the new options for check_snmp --rate and --rate-multiplier.
When I execute the command from the CLI (as root) it seems to work as expected:
[root@VAULT23 libexec]# ./check_snmp -H 192.168.105.2 -o .1.3.6.1.4.1.8741.1.3.1.3.0 -C public -P 2c -l "" -u % --rate --rate-multiplier=60
SNMP RATE OK -  120082962.6 % | =120082962.6
When I add a service that executes the same command I get an Unknown status with Cannot create temporary filename.
If I create an identical check without the --rate --rate-multiplier=60 arguments the command works fine.
mguthrie
Re: check_snmp - Cannot create temporary filename
Post by mguthrie »
It's probably a permissions issue. What happens if you run:
chmod u+s check_snmp
This will make it so that this plugin always runs as root
Post by Box293 »
Bingo, that fixed the problem :D
Much appreciated
mguthrie
Post by mguthrie »
You bet!
