How do I change the SNMP community string on a host
pclements
Post by pclements »
First I am new to Nagios.
How do I display the configuration of a host including the SNMP string monitored properties (hostname, date time, status, interfaces, etc) and then change the community sting. I am using the latest version of Nagios XI on CentOS. Another question How do I globally change the SNMP community string for all hosts at the same time?
Thank you,
avandemore
Re: How do I change the SNMP community string on a host
Post by avandemore »
It depends on exactly what context you are talking about, but the service definition would be the most common place. Using a template, you can change the template and have it apply to all the services using it.
Previous Nagios employee
To build off of what @avandemore mentioned, templates are a really good way to control things on a large scale. (in conjunction with host groups)
If you're just looking at a dynamic way to control only the community string, take a look at how your checks are setup. You may be able to use a $USER#$ macro from resource.cfg to populate anywhere in the XI instance. https://assets.nagios.com/downloads/nag ... Macros.pdf
Post by dwhitfield »
You could also do it in the Bulk Modifications Tool, if you are an Enterprise customer.
pclements
Post by pclements »
Thank you all for your help.
cdienger
Post by cdienger »
Are we okay closing the thread at this point?
pclements
Post by pclements »
Yes, thank you.
