How to monitor a perticular nagios server with other nagios
shivakumar
Post by shivakumar »
How to monitor a perticular nagios server with other nagios server?
I need to get alert if one nagios server goes down. Is there any cfg file that could help me to configure it?
cdienger
Re: How to monitor a perticular nagios server with other nag
Post by cdienger »
Greetings you could use the Nagios XI Server wizard found under Configure > Configuration Wizards to make sure the remote Nagios server is up and has the proper services running.
shivakumar
Thanks for the reply. Am looking for a cfg file to monitor nagios.
cdienger
Post by cdienger »
Here is the host definition created by the wizard:
define host {
host_name 192.168.3.120
use xiwizard_nagiosxiserver_host
address 192.168.3.120
max_check_attempts 1
check_interval 1
retry_interval 1
contacts nagiosadmin
notification_interval 60
_xiwizard nagiosxiserver
register 1
And here are the services:
service_description HTTP
use xiwizard_nagiosxiserver_http_service
check_interval 1
retry_interval 1
register 1
service_description I/O Wait
use xiwizard_nagiosxiserver_service
check_command check_xi_nagiosxiserver!--address=192.168.3.120 --url=http://192.168.3.120/nagiosxi/ --username=nagiosadmin --ticket="Km35RGJE" --mode=iowait --warn="5" --crit="15"
check_interval 1
retry_interval 1
register 1
service_description Load
check_command check_xi_nagiosxiserver!--address=192.168.3.120 --url=http://192.168.3.120/nagiosxi/ --username=nagiosadmin --ticket="Km35RGJE" --mode=load --warn="5,4,4" --crit="10,10,7"
check_interval 1
retry_interval 1
register 1
service_description Nagios XI Daemons
check_command check_xi_nagiosxiserver!--address=192.168.3.120 --url=http://192.168.3.120/nagiosxi/ --username=nagiosadmin --ticket="Km35RGJE" --mode=daemons
check_interval 1
retry_interval 1
register 1
service_description Nagios XI Jobs
check_command check_xi_nagiosxiserver!--address=192.168.3.120 --url=http://192.168.3.120/nagiosxi/ --username=nagiosadmin --ticket="Km35RGJE" --mode=jobs
check_interval 1
retry_interval 1
register 1
service_description Ping
use xiwizard_nagiosxiserver_ping_service
check_interval 1
retry_interval 1
register 1
Obviously change the IP address and ticket to your unique values. The ticket can be gathered from the backend api by going to http://ipofremotenagiosserver/nagiosxi/ ... agiosadmin password=40be4e59b9a2a2b5dffb918c0e86b3d7 where 40be4e59.... is the md5 hash of the nagiosadmin password.
