Panzura Monitoring in Nagios
suryahcl
Post by suryahcl »
Hi All,
We have Panzura storage gateway in our environment. I have a question can we monitor Panzura in Nagios XI.
Regards
Surya Pratap Singh
+91 9953982980
Re: Panzura Monitoring in Nagios
Post by dwhitfield »
You may need to modify things based on version #s, but there is a plugin that exists: https://exchange.nagios.org/directory/P ... ra/details
If you can find applicable OID's to monitor the SNMP walk wizard will be your friend.
I doubt you really need these with the plugin I sent, but if that plugin and the SNMP Wizard don't work for you, then you should take a look at https://nagios-plugins.org/doc/guidelines.html
