Hi
I am attching 2 pictures so that you can understand what i am trying to say /
1. new.PNG file will tell about workflow between our products and nagios products.
So please send how the API's should be interacted with our products and nagios (/ custom Nagios plugin to interact with Vision MSM REST API)
2. Capture.PNG will give brief introduction about our products.
- Former Nagios Staff
Re: custom Nagios plugin to interact with Vision MSM REST AP
If you want us to write a custom plugin for a fee, you will need to email [email protected]. We don't currently have expertise in Vision MSM REST API. You will probably need to talk to them about that.
As for writing custom plugins, you can find the guidelines at https://nagios-plugins.org/doc/guidelines.html
This is more a question for whomever is developing the work flow for your API.So please send how the API's should be interacted with our products and nagios (/ custom Nagios plugin to interact with Vision MSM REST API)
For information on what XI can do, see the 'Help' menu from the XI menu. If you'd like to automate the process, see the document attached I wrote a while back.
avandemore
Also here is some information on developing custom plugins:
https://mathias-kettner.de/checkmk_localchecks.html
http://www.yourownlinux.com/2014/06/how ... cript.html
Previous Nagios employee
