Hi again,
currently migrating form old XI to latest version. I have notes defined on every host that we monitor. is there a way to get this data imported into my new install?
XI Object Notes
avandemore
Re: XI Object Notes
It will come across with a standard backup/restore migration or even a migrate from core approach:
https://assets.nagios.com/downloads/nag ... ios_XI.pdf
Previous Nagios employee
Re: XI Object Notes
so it is ok to restore this version over the to the latest database?
Nagios XI Version : 2012R2.7
nagiosxi.hasbro.com 2.6.32-573.26.1.el6.x86_64 x86_64
CentOS release 6.7 (Final)
Gnome is not installed
avandemore
Re: XI Object Notes
I recommend using the core migration method in that case. One of the main reasons for this is that postgresql is no longer used in current installs. If you tried to do a backup/restore it would pull in postgresql because of the legacy stuff. A core migration is a few more steps on the front-end, but overall it is a cleaner approach coming from that old of Nagios XI version.
Re: XI Object Notes
ok sounds good, Ill give it a shot. you can close this, I will post again if I have issues.
thanks again
thanks again
