Nagios disk usage check and reserved root space
dtidwell1224
Post by dtidwell1224 »
The "check_snmp_storage_wizard.pl, and check_snmp_storage.pl" checks do not appear to be monitoring disk usage correctly.
When running the following command, I get 75%:
[root@nagioshost libexec]# /usr/local/nagios/libexec/check_snmp_storage_wizard.pl -H anon01 -C redacted --v2c -m "^/mariadb/data$" -w 80 -c 95 -f
/mariadb/data: 75%used(75565MB/100665MB) (<80%) : OK | '/mariadb/data'=75565MB;80532;95632;0;100665
[root@nagioshost libexec]# /usr/local/nagios/libexec/check_snmp_storage.pl -H anon01 -C redacted --v2c -m "^/mariadb/data$" -w 80 -c 95 -f
However when I run df on the actual box, It appears off by 5%:
[user@anon01 ~]$ df -h | grep data
/dev/mapper/volumegroup-lv_mariadb_data 99G 74G 20G 80% /mariadb/data
It appears that this Nagios check does not take into account the reserved root space.
While I understand that I could lower the reserved space, I would prefer not to do so on this system, as it is essential for root to be able to login and access system services, etc... in the event of a problem
Is it possible with any flag or modification to the script(s) to account for the reserved space?
avandemore
Re: Nagios disk usage check and reserved root space
Post by avandemore »
I think you're missing the snmp part, the plugin is going to return what snmp sends. You'll need to customize your snmp daemon if you want that check to reflect differently:
https://thwack.solarwinds.com/thread/50578
You may have an easier time of it if you install an active agent and have it report the results. Then reservations can be taken into account by the plugin.
Previous Nagios employee
