Nagios XI - Installation support on other Language
rajshekar_p
Post by rajshekar_p »
Hi Team,
Apart from English OS flavor, does Nagios XI support installation on any other language OS.
Thanks & Regards,
Rajshekar P
Re: Nagios XI - Installation support on other Language
Post by mcapra »
I would have to know the language/charset being used specifically. We don't do much testing against non-english systems. You're certainly welcome to try it though.
I would recommend not changing the systems language/charset after Nagios XI is installed as that could cause problems with Python and Perl based plugins.
There are some known issues that can happen with performance data:
https://support.nagios.com/kb/article.php?id=10
rajshekar_p
We are trying to install on below languages. Please let us if Nagios XI installation is supported officially on below languages.
Single Byte:
Traditional Chinese
Simplified Chinese
Korean
Japanese
Double Byte:
French
German
Spanish
Thanks & Regards,
Rajshekar P
Post by dwhitfield »
As was already mentioned, https://support.nagios.com/kb/article.php?id=10 may be an issue.
We will support XI on these languages, but if it turns out the language causes an issue, there may not be anything we can do. To reiterate, we do not do much testing on OS languages other than English. Many of our plugins are contributed by third-parties, so we have no control over their language support.
In the interface itself, we do support all of those languages and more (for example, Italian).
You may also be interested in https://assets.nagios.com/downloads/nag ... ations.pdf
