This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
nfv_nagios
Posts: 35 Joined: Sun Jan 08, 2017 8:00 pm
Post
by nfv_nagios » Thu Mar 23, 2017 4:30 am
Hi Support
I have a query. Can you assist?
I am running Nagios XI 2014R1.3.
When i want to see the Alert History and Event Log reports, the format is not aligned to the left.
Please see screen shot.
Is there a way to make it align to the left?
Thank you.
Posts: 3739 Joined: Thu May 05, 2016 3:54 pm
Post
by mcapra » Thu Mar 23, 2017 12:29 pm
Which browser are you using? Does the display look the same from the regular Nagios GUI? (access via http://<host>/nagios).
Can you also send over the following files from your Nagios XI machine:
/usr/local/nagios/share/stylesheets/showlog.css
/usr/local/nagiosxi/html/includes/components/nagioscore/ui/css/orig/showlog.css
/usr/local/nagiosxi/html/includes/components/nagioscore/ui/css/showlog.css
/usr/local/nagios/share/stylesheets/common.css
/usr/local/nagiosxi/html/includes/components/nagioscore/ui/css/orig/common.css
/usr/local/nagiosxi/html/includes/components/nagioscore/ui/css/common.css
nfv_nagios
Post
by nfv_nagios » Thu Mar 23, 2017 9:34 pm
Hi Support
I am using Google Chrome Version 57.0.2987.110.
I tried on IE and i don't see the same problem. Any advise how to fix the Chrome display issue? Most of my end users are using Chrome.
Posts: 9117 Joined: Mon Sep 23, 2013 8:40 am
Post
by tmcdonald » Fri Mar 24, 2017 12:48 pm
Could you address the other questions?
mcapra wrote: Does the display look the same from the regular Nagios GUI? (access via http://<host>/nagios).
mcapra wrote: Can you also send over the following files from your Nagios XI machine:
nfv_nagios
Post
by nfv_nagios » Mon Apr 10, 2017 8:57 pm
Hi, sorry for the late response.
Yes, the display look the same from the regular Nagios GUI.
Attached are the CSS files requested.
ssax
Dreams In Code
Posts: 7682 Joined: Wed Feb 11, 2015 12:54 pm
Post
by ssax » Tue Apr 11, 2017 2:26 pm
The CSS files are proper, please display the page in Chrome, right-click in the right hand window then click View Frame Source and attach the full source.
Thank you
nfv_nagios
Post
by nfv_nagios » Sun Apr 16, 2017 10:26 pm
As requested, attached is the output of "View Frame Source"
Post
by mcapra » Mon Apr 17, 2017 1:33 pm
Are you certain there isn't some sort of extension in Chrome that's causing this? Does this happen in IE and Firefox as well? I'm using that exact same page with your exact same CSS and I cannot reproduce this. Is your Nagios XI including some CSS/Javascript via the "Custom Includes" component?
