ncpa agent inside a docker container
kendallchenoweth
Post by kendallchenoweth »
I'm trying to install an NCPA agent inside a docker container and getting the error below. Can you please tell me how to fix this and if you have any recommendations for using NCPA (or something else) to monitor within a docker container?
stderr] Traceback (most recent call last):
[stderr] File "/usr/local/lib/python2.7/site-packages/cx_Freeze-4.3.4-py2.7-linux-x86_64.egg/cx_Freeze/initscripts/Console.py", line 27, in <module>
[stderr] File "ncpa_posix_listener.py", line 6, in <module>
[stderr] File "/root/Development/ncpa/agent/listener/server.py", line 8, in <module>
[stderr] File "/root/Development/ncpa/agent/listener/psapi.py", line 170, in <module>
[stderr] File "/root/Development/ncpa/agent/listener/psapi.py", line 143, in get_root_node
[stderr] File "/root/Development/ncpa/agent/listener/psapi.py", line 113, in get_disk_node
[stderr] File "/usr/local/lib/python2.7/site-packages/psutil/__init__.py", line 1728, in disk_partitions
[stderr] File "/usr/local/lib/python2.7/site-packages/psutil/_pslinux.py", line 620, in disk_partitions
[stderr] OSError: [Errno 2] No such file or directory: '/etc/mtab'
Thanks!
avandemore
Re: ncpa agent inside a docker container
Post by avandemore »
You could create an empty mtab:
touch /etc/mtab
This might also work:
ln -s /proc/mounts /etc/mtab
Previous Nagios employee
