Logserver creating multiple sessions via FW to AD
james.liew
Hi all,
NLS is creating multiple sessions to our LDAP/AD server.
I have a firewall in-between that's throwing alerts due to the amount of sessions being opened. How do I stop this from happening?
I can provide logs etc.
Screenshot attached.
avandemore
Re: Logserver creating multiple sessions via FW to AD
If the LS OS is Cent/RHEL 7, what is the output of:
If the LS OS is Cent/RHEL 6, what is the output of:
# ss -tunaCode: Select all
netstat -tunaPrevious Nagios employee
james.liew
I filtered the results... see below.
[root@hs1-log-01 ~]# ss -tuna | grep 172.16.17.1
tcp ESTAB 0 0 ::ffff:172.16.21.37:3515 ::ffff:172.16.17.1:64854
Is your AD server also your DNS server? Looks like the Application listed in your report in the OP is DNS.
james.liew
it is, yes.scottwilkerson wrote:Is your AD server also your DNS server? Looks like the Application listed in your report in the OP is DNS.
Is this normal behaviour?
The version of Logstash we are currently using in Nagios Log Server tends to keep connections open until they're very stale, so that sort of behavior isn't terrible surprising to me.
Can you share the Logstash configurations you're using? This should provide them:
grep '' /usr/local/nagioslogserver/logstash/etc/conf.d/*
james.liew
Amended some ports to hide them. Sorry 'bout that.
/usr/local/nagioslogserver/logstash/etc/conf.d/000_inputs.conf:#
/usr/local/nagioslogserver/logstash/etc/conf.d/000_inputs.conf:# Logstash Configuration File
/usr/local/nagioslogserver/logstash/etc/conf.d/000_inputs.conf:# Dynamically created by Nagios Log Server
/usr/local/nagioslogserver/logstash/etc/conf.d/000_inputs.conf:# DO NOT EDIT THIS FILE. IT WILL BE OVERWRITTEN.
/usr/local/nagioslogserver/logstash/etc/conf.d/000_inputs.conf:# Created Tue, 03 Jan 2017 13:16:12 +0100
/usr/local/nagioslogserver/logstash/etc/conf.d/000_inputs.conf:# Global inputs
/usr/local/nagioslogserver/logstash/etc/conf.d/000_inputs.conf:input {
/usr/local/nagioslogserver/logstash/etc/conf.d/000_inputs.conf: syslog {
/usr/local/nagioslogserver/logstash/etc/conf.d/000_inputs.conf: type => 'syslog'
/usr/local/nagioslogserver/logstash/etc/conf.d/000_inputs.conf: port => *
/usr/local/nagioslogserver/logstash/etc/conf.d/000_inputs.conf: }
/usr/local/nagioslogserver/logstash/etc/conf.d/000_inputs.conf: type => 'switches'
/usr/local/nagioslogserver/logstash/etc/conf.d/000_inputs.conf: tcp {
/usr/local/nagioslogserver/logstash/etc/conf.d/000_inputs.conf: type => 'eventlog'
/usr/local/nagioslogserver/logstash/etc/conf.d/000_inputs.conf: codec => json {
/usr/local/nagioslogserver/logstash/etc/conf.d/000_inputs.conf: charset => 'CP1252'
/usr/local/nagioslogserver/logstash/etc/conf.d/000_inputs.conf: type => 'import_raw'
/usr/local/nagioslogserver/logstash/etc/conf.d/000_inputs.conf: tags => 'import_raw'
/usr/local/nagioslogserver/logstash/etc/conf.d/000_inputs.conf: type => 'import_json'
/usr/local/nagioslogserver/logstash/etc/conf.d/000_inputs.conf: tags => 'import_json'
/usr/local/nagioslogserver/logstash/etc/conf.d/000_inputs.conf:}
/usr/local/nagioslogserver/logstash/etc/conf.d/000_inputs.conf:# Local inputs
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf:#
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf:# Logstash Configuration File
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf:# Dynamically created by Nagios Log Server
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf:# DO NOT EDIT THIS FILE. IT WILL BE OVERWRITTEN.
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf:# Created Tue, 03 Jan 2017 13:16:12 +0100
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf:# Global filters
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf:filter {
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf: if [program] == 'apache_access' {
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf: grok {
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf: match => [ 'message', '%{COMBINEDAPACHELOG}']
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf: }
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf: date {
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf: match => [ 'timestamp', 'dd/MMM/yyyy:HH:mm:ss Z' ]
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf: mutate {
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf: replace => [ 'type', 'apache_access' ]
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf: convert => [ 'bytes', 'integer' ]
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf: convert => [ 'response', 'integer' ]
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf: if [program] == 'apache_error' {
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf: match => [ 'message', '\[(?<timestamp>%{DAY:day} %{MONTH:month} %{MONTHDAY} %{TIME} %{YEAR})\] \[%{WORD:class}\] \[%{WORD:originator} %{IP:clientip}\] %{GREEDYDATA:errmsg}']
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf: replace => [ 'type', 'apache_error' ]
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf: dns {
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf: reverse => ['host']
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf: action => ['replace']
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf: add_tag => ['dns']
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf:}
/usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf:# Local filters
/usr/local/nagioslogserver/logstash/etc/conf.d/999_outputs.conf:#
/usr/local/nagioslogserver/logstash/etc/conf.d/999_outputs.conf:# Logstash Configuration File
/usr/local/nagioslogserver/logstash/etc/conf.d/999_outputs.conf:# Dynamically created by Nagios Log Server
/usr/local/nagioslogserver/logstash/etc/conf.d/999_outputs.conf:# DO NOT EDIT THIS FILE. IT WILL BE OVERWRITTEN.
/usr/local/nagioslogserver/logstash/etc/conf.d/999_outputs.conf:# Created Tue, 03 Jan 2017 13:16:12 +0100
/usr/local/nagioslogserver/logstash/etc/conf.d/999_outputs.conf:# Required output for Nagios Log Server
/usr/local/nagioslogserver/logstash/etc/conf.d/999_outputs.conf:output {
/usr/local/nagioslogserver/logstash/etc/conf.d/999_outputs.conf: elasticsearch {
/usr/local/nagioslogserver/logstash/etc/conf.d/999_outputs.conf: cluster => '1d9ff623-2ffd-4407-b023-ef71f56139d2'
/usr/local/nagioslogserver/logstash/etc/conf.d/999_outputs.conf: host => 'localhost'
/usr/local/nagioslogserver/logstash/etc/conf.d/999_outputs.conf: document_type => '%{type}'
/usr/local/nagioslogserver/logstash/etc/conf.d/999_outputs.conf: node_name => '791cc6c8-f646-495e-9e58-1ec21a24b61c'
/usr/local/nagioslogserver/logstash/etc/conf.d/999_outputs.conf: protocol => 'transport'
/usr/local/nagioslogserver/logstash/etc/conf.d/999_outputs.conf: workers => 4
/usr/local/nagioslogserver/logstash/etc/conf.d/999_outputs.conf: }
/usr/local/nagioslogserver/logstash/etc/conf.d/999_outputs.conf:}
/usr/local/nagioslogserver/logstash/etc/conf.d/999_outputs.conf:# Global outputs
/usr/local/nagioslogserver/logstash/etc/conf.d/999_outputs.conf:# Local outputs
/usr/local/nagioslogserver/logstash/etc/conf.d/999_outputs.conf:Re: Logserver creating multiple sessions via FW to AD
I don't have the equipment to properly test/reproduce this, but i'm betting the dns filter is what's causing those sessions :
Basically, every time Logstash receives an event, it's going to run it through that filter which is going to attempt to query the DNS server for the reverse lookup. For every event, a brand-new reverse DNS request.
dns {
reverse => ['host']
add_tag => ['dns']
}Former Nagios employee
james.liew
Is it possible to do without this?
Thanks!
Thanks!
- tacolover101
well your filter kind of depends on DNS at that point so probably a better question to ask yourself - can you deal without translation?
you might be able to add ALL static entries to /etc/hosts
