MOD EDIT: This was split from https://support.nagios.com/forum/viewtopic.php?t=43120
That did it, thanks!! Everything has started to go green. Does anyone have advice on how to allow ping between LAN hosts in Azure?
Ping in Azure
InscrutableDude
Ping in Azure
Reason: new issue
Reason: new issue
- Former Nagios Staff
Re: Testing Problems - First Host Unavailable
This is not really a Nagios issue, but according to http://stackoverflow.com/questions/9783 ... p-on-azure it looks like you need to set a public IP address.InscrutableDude wrote:Does anyone have advice on how to allow ping between LAN hosts in Azure?
InscrutableDude
Maybe I spoke too soon. While all services are listed as ok, the host continues to be listed as down: "CRITICAL - 10.3.0.29: rta nan, lost 100%"
Does this have to do with ping, or something else?
Please use https://support.nagios.com/forum/viewtopic.php?t=43120 for your Nagios issue.
Are we ready to lock this up in regards to turning on ping in Azure?
InscrutableDude
Re: Ping in Azure
Not really, no. As far as I can tell, all nagios machines come with both internal and external IPs. Second, I don't want the machines to be pingable from the WAN. I just want ping to work on the LAN.
Re: Ping in Azure
You can change the Host check to use something else if you like...meaning, a different type of check, maybe a http check? Depends on the server.
