HTTP URL monitor not working
Trying to deploy a Website URL monitor but got "HTTP CRITICAL: HTTP/1.1 503 Service Temporarily Unavailable" error. This website works fine when manually testing but it is protected by a 3rd party front-end called CloudFlare. I need to configure the HTTP monitor to work this front end.
avandemore
Re: HTTP URL monitor not working
Here is the documentation for the check:
https://nagios-plugins.org/doc/man/check_http.html
What syntax are you using?
Previous Nagios employee
I use the Configuration Wizards -> Website URL monitor -> URL Status and URL Content
For URL Status, it is check_xi_service_http -f ok -I 104.16.92.31 -u '/' -S -p 443
For URL Content, it is check_xi_service_http -s "contentxxx" -f ok -I xxx.xxx.xxx.xxx -u '/' -S -p 443
Greetings, Are you still getting 503 errors? 503 usually indicates a problem with the service or problems between nagios and the http server.
I tested the commands and I get a 403 Forbidden message. It appears the site requires a valid Host header. This needs to be included with the -H option:
-f ok -I 104.16.92.31 -u '/' -S -p 443 -H <HOSTNAME>
Sorry for '-H <HOSTNAME>', <HOSTNAME> would be the Nagios server name?
Sorry for not being clear: -H would be the hostname of the destination server. www.example.com for example.
Here's what I tested with the same failure.
COMMAND: /usr/local/nagios/libexec/check_http -H images.nga.gov -f ok -I 104.16.92.31 -u '/' -S -p 443
OUTPUT: HTTP CRITICAL: HTTP/1.1 503 Service Temporarily Unavailable - 5072 bytes in 0.035 second response time |time=0.034862s;;;0.000000 size=5072B;;;0
Greetings, I am receiving a 503 message as well. It appears there may be something wrong with the service as the 503 code points to. The same command with other sites work. For example:
/usr/local/nagios/libexec/check_http -H www.google.com -f ok -I 74.125.193.105 -u '/' -S -p 443
avandemore
The response you are getting from cloudflare is correct. That's what you sign up for when using that service:
Do you this enabled or something? https://blog.cloudflare.com/introducing ... tack-mode/
# curl -Iv https://images.nga.gov/
* About to connect() to images.nga.gov port 443 (#0)
* Trying 104.16.91.31...
* Connected to images.nga.gov (104.16.91.31) port 443 (#0)
* Initializing NSS with certpath: sql:/etc/pki/nssdb
* CAfile: /etc/pki/tls/certs/ca-bundle.crt
CApath: none
* SSL connection using TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
* Server certificate:
* subject: CN=images.nga.gov
* start date: Mar 31 00:00:00 2016 GMT
* expire date: May 30 23:59:59 2019 GMT
* common name: images.nga.gov
* issuer: CN=RapidSSL SHA256 CA,O=GeoTrust Inc.,C=US
> HEAD / HTTP/1.1
> User-Agent: curl/7.29.0
> Host: images.nga.gov
> Accept: */*
< HTTP/1.1 503 Service Temporarily Unavailable
< Date: Thu, 30 Mar 2017 14:34:09 GMT
< Content-Type: text/html; charset=UTF-8
< Connection: close
Connection: close
< Set-Cookie: __cfduid=de86e3ac00c6c335c7ff337c76413fd241490884449; expires=Fri, 30-Mar-18 14:34:09 GMT; path=/; domain=.nga.gov; HttpOnly
< X-Frame-Options: SAMEORIGIN
< Refresh: 8;URL=/cdn-cgi/l/chk_jschl?pass=1490884453.373-IlY/B/i+bn
< Cache-Control: no-cache
< Server: cloudflare-nginx
< CF-RAY: 347bc9c099075540-ORD
* Closing connection 0Previous Nagios employee
We use CloudFlare to protect our website including from robots, but how come it works with manual checking from browsers? Is there a different way Nagios can check on the health of URLs?
