Reduce the size of my Nagios back ups....
JakeHatMacys
Right now the last back ups that worked were 8gb's in size and every other one I attempt to get to run ends up failing with a large directory being made instead of a functional back up...
I'm not sure if the /tmp directory is running out of space as I think it uses that to swap with to build the back up??? Regardless i'm going to guess it's host & service history that got us to this point where our back ups are so big. Is there a good utility I can run to say delete a lot of our older data?
If not what would you recommend doing to reduce our back up sizes??? (my version is 2014R2.7 but I plan on upgrading within the next 2 months if possible... but I need a current back up!)
avandemore
Re: Reduce the size of my Nagios back ups....
Another option may be to grow your filesystem, here is a doc on that:
https://assets.nagios.com/downloads/nag ... M-Disk.pdf
What is the output of:
# du -shcx /usr/local/nagios/*
# du -shcx /var/lib/*
# df -h
# df -iPrevious Nagios employee
SteveBeauchemin
Once upon a time - I noticed in my setup that automated backups were incomplete, but a manually run backup was okay.
If that is what you are experiencing, I was told to add one line to a php file, which then did solve my problem.
The file is /usr/local/nagiosxi/html/config.inc.php
And I added to the bottom...
The manually run backup worked though. Maybe try running it from the command line once and see if it works for you manually.
The file is in /usr/local/nagiosxi/scripts and is named backup_xi.sh
For your version of Nagios, I would probably run that as the root user just because.
Steve B
// prevent backup process from creating incomplete files
$cfg['backup_timeout'] = 3600;
./backup_xi.shXI 5.7.3 / Core 4.4.6 / NagVis 1.9.8 / LiveStatus 1.5.0p11 / RRDCached 1.7.0 / Redis 3.2.8 /
SNMPTT / Gearman 0.33-7 / Mod_Gearman 3.0.7 / NLS 2.0.8 / NNA 2.3.1 /
NSClient 0.5.0 / NRPE Solaris 3.2.1 Linux 3.2.1 HPUX 3.2.1
Thanks Steve! @OP let us know if more questions.
JakeHatMacys
Thanks for the feedback... will try it now. Root? What's that? *cries* they took away our keys a long time ago. I can't do crap without a form and a week long wait... here's hoping our ACL's set up cover it...SteveBeauchemin wrote:Once upon a time - I noticed in my setup that automated backups were incomplete, but a manually run backup was okay.
And I added to the bottom...The manually run backup worked though. Maybe try running it from the command line once and see if it works for you manually.Code: Select all
// prevent backup process from creating incomplete files $cfg['backup_timeout'] = 3600;
For your version of Nagios, I would probably run that as the root user just because.Steve BCode: Select all
cd /usr/local/nagiosxi/scripts ./backup_xi.sh
JakeHatMacys
I have grown the file system which I don't think is the issue (/tmp alone is 30 gigs) but the problem with your DOC is it wants me to take a back up first which isn't workingavandemore wrote:Another option may be to grow your filesystem, here is a doc on that:
What is the output of:Code: Select all
# du -shcx /usr/local/nagios/* # du -shcx /var/lib/* # df -h # df -i
A VM level snapshot would also be appropriate. Or if you have a backup from a previous time period, that would work also. I realize the frustration in your case, but the docs include a backup step because resizing a file system can be dangerous if done irresponsibly.
- Former Nagios Staff
In addition to what @mcapra said, please provide output for the following commands:
Those two commands that @avandemore gave you will help us determine what in Nagios is so large.
Database corruption of a sort can cause this.
Please log into MySQL and run the following and provide output:
du -shcx /var/lib/*
SELECT table_schema "DB Name",
Round(Sum(data_length + index_length) / 1024 / 1024, 1) "DB Size in MB"
FROM information_schema.tables
GROUP BY table_schema;
JakeHatMacys
I'll have to get back to you on MySQL on the selec statements. Was just issued a new laptop and need to install the software to connect to the DB.dwhitfield wrote:In addition to what @mcapra said, please provide output for the following commands:
Those two commands that @avandemore gave you will help us determine what in Nagios is so large.Code: Select all
du -shcx /usr/local/nagios/* du -shcx /var/lib/*
Please log into MySQL and run the following and provide output:Code: Select all
SELECT table_schema "DB Name", Round(Sum(data_length + index_length) / 1024 / 1024, 1) "DB Size in MB" FROM information_schema.tables GROUP BY table_schema;
[nagios@******** scripts]$ du -shcx /usr/local/nagios/*
1.6M /usr/local/nagios/bin
16M /usr/local/nagios/etc
4.0K /usr/local/nagios/include
11M /usr/local/nagios/libexec
5.6M /usr/local/nagios/sbin
37G /usr/local/nagios/share
580K /usr/local/nagios/sshpass-1.05
376K /usr/local/nagios/sshpass-1.05.tar
536K /usr/local/nagios/sshpas.tar
40G /usr/local/nagios/var
77G totalCode: Select all
[nagios@********* scripts]$ du -shcx /var/lib/*
52K /var/lib/alternatives
du: cannot read directory `/var/lib/authconfig': Permission denied
4.0K /var/lib/authconfig
32K /var/lib/cas
du: cannot read directory `/var/lib/certmonger/requests': Permission denied
du: cannot read directory `/var/lib/certmonger/local': Permission denied
du: cannot read directory `/var/lib/certmonger/cas': Permission denied
16K /var/lib/certmonger
du: cannot read directory `/var/lib/dav': Permission denied
4.0K /var/lib/dav
8.0K /var/lib/dbus
4.0K /var/lib/DeviceKit-power
4.0K /var/lib/dhclient
4.0K /var/lib/fprint
4.0K /var/lib/games
du: cannot read directory `/var/lib/gdm': Permission denied
4.0K /var/lib/gdm
4.0K /var/lib/hiera
8.0K /var/lib/ipa-client
4.0K /var/lib/logrotate.status
4.0K /var/lib/misc
du: cannot read directory `/var/lib/mlocate': Permission denied
4.0K /var/lib/mlocate
4.0K /var/lib/mrtg
du: cannot read directory `/var/lib/mysql/mysql': Permission denied
du: cannot read directory `/var/lib/mysql/nagiosql': Permission denied
du: cannot read directory `/var/lib/mysql/test': Permission denied
du: cannot read directory `/var/lib/mysql/nagios': Permission denied
21M /var/lib/mysql
du: cannot read directory `/var/lib/net-snmp/mib_indexes': Permission denied
12K /var/lib/net-snmp
du: cannot read directory `/var/lib/nfs/statd': Permission denied
12K /var/lib/nfs
8.0K /var/lib/ntp
du: cannot read directory `/var/lib/pgsql': Permission denied
4.0K /var/lib/pgsql
du: cannot read directory `/var/lib/php/session': Permission denied
500K /var/lib/php
8.0K /var/lib/plymouth
du: cannot read directory `/var/lib/polkit-1': Permission denied
4.0K /var/lib/polkit-1
du: cannot read directory `/var/lib/postfix': Permission denied
4.0K /var/lib/postfix
12K /var/lib/prelink
du: cannot read directory `/var/lib/puppet': Permission denied
4.0K /var/lib/puppet
32K /var/lib/qpidd
4.0K /var/lib/random-seed
36K /var/lib/readahead
8.0K /var/lib/rhncfg
20K /var/lib/rhsm
107M /var/lib/rpm
du: cannot read directory `/var/lib/rsyslog': Permission denied
4.0K /var/lib/rsyslog
du: cannot read directory `/var/lib/samba/winbindd_privileged': Permission denied
du: cannot read directory `/var/lib/samba/private': Permission denied
16K /var/lib/samba
du: cannot read directory `/var/lib/sss/pipes/private': Permission denied
du: cannot read directory `/var/lib/sss/keytabs': Permission denied
du: cannot read directory `/var/lib/sss/db': Permission denied
36K /var/lib/sss
12K /var/lib/stateless
4.0K /var/lib/supportinfo
8.0K /var/lib/udev
4.0K /var/lib/up2date
12K /var/lib/uptrack
12K /var/lib/vmware
8.0K /var/lib/xkb
du: cannot read directory `/var/lib/yum/history/2013-02-25/17': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/28': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/20': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/16': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/10': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/6': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/31': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/26': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/13': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/7': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/23': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/29': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/30': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/11': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/14': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/25': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/2': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/32': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/1': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/5': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/3': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/15': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/18': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/33': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/8': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/27': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/4': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/24': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/12': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/22': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/21': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/9': Permission denied
du: cannot read directory `/var/lib/yum/history/2013-02-25/19': Permission denied
13M /var/lib/yum
140M total
[nagios@******** scripts]$Code: Select all
[nagios@******* scripts]$ ./repair_databases.sh
mysqld (pid 6427) is running...
DATABASE: nagios
TABLE:
/usr/local/nagiosxi/scripts/repairmysql.sh: line 49: pushd: /var/lib/mysql/nagios: Permission denied
ERROR: Could not change to dir: /var/lib/mysql/nagios
DATABASE: nagiosql
TABLE:
/usr/local/nagiosxi/scripts/repairmysql.sh: line 49: pushd: /var/lib/mysql/nagiosql: Permission denied
ERROR: Could not change to dir: /var/lib/mysql/nagiosql
Stopping ndo2db: head: cannot open `/usr/local/nagios/var/ndo2db.lock' for reading: No such file or directory
done.
Starting ndo2db: done.
Running configuration check...
Stopping nagios:. done.
Starting nagios: done.
What are the permissions on /var/lib/mysql/? You say they are the same permissions, but did you check (assuming it is possible for you to check)? I know that that *should* have the same permissions, but maybe that was changed accidentally.
Since you have a custom setup, it might make sense to email [email protected] and reference this thread. The downside is no community help, and it is always up to you, but it's going to be difficult with a custom environment without really taking a look at what is actually going on.
