I can't upgrade from nagios xi 5.4.0 to a more recent version.
I tried, with no result, to follow the posts :
- https://support.nagios.com/forum/viewto ... 16&t=31779
- https://support.nagios.com/forum/viewto ... 6&start=10
In attachment I give you the result of "./upgrade | tee /tmp/upgrade.txt"
Regards
NAGIOSQL LOGIN FAILED, after upgrad
Re: NAGIOSQL LOGIN FAILED, after upgrad
Greetings,
I've responded to the ticket you've filed regarding this issue. We can correspond directly via email and close the thread if you'd like.
