NRPE installation
krishnar
NRPE installation
Post by krishnar »
Hi All,
I need help with installing NRPE is my lab Nagios Server. I have follow these instruction to install NRPE:
wget https://github.com/NagiosEnterprises/nrpe/archive/3.0.1.tar.gz
gunzip  3.0.1.tar.gz
tar -xf 3.0.1.tar
cd nrpe-3.0.1/
./configure --with-nagios-user=nagios --with-nagios-group=nagios
make
make all
make install
This configuration install NRPE plug to /usr/local/nagios folder. However, my Nagios is running in /opt/nagios.
Is there any way I can change the installation path to /opt/nagios ?
Re: NRPE installation
When you run the configure script, you can change the destination of where the Agent is installed by using the prefix option.
In your case, you would run the following to install in the /opt/nagios folder.
./configure --with-nagios-user=nagios --with-nagios-group=nagios --prefix=/opt/nagios
krishnar
Post by krishnar »
Thank you for helping me..I have got one more query.
[user@krishnar1 etc]$ cat nrpe.cfg | egrep ^command.*check_users
command[check_users]=/usr/local/nagios/libexec/check_users -w $ARG1$ -c $ARG2$
I have the above config in my remote host. I am not able to do the check from Nagios Core with passing the arguments.
-bash-4.2$ ./check_nrpe -H 172.31.116.108 -4 -c check_users -a 1 2
NRPE: Command 'check_users!1!2' not defined
-bash-4.2$
But this works fine!
USERS OK - 1 users currently logged in |users=1;5;10;0
-bash-4.2$
Any help would be appreciated.
krishnar
Post by krishnar »
After NRPE service restart in Remote host:
check_users: Warning threshold must be a positive integer
Usage:
check_users -w <users> -c <users>
-bash-4.2$
-bash-4.2$
-bash-4.2$ ./check_nrpe -H 172.31.116.108 -4 -c check_users -a 5 10
Usage:
-bash-4.2$
There is a setting in the nrpe.cfg file called dont_blame_nrpe option. If it is set to 0, this disables the ability to pass arguments to the NRPE Agent and could be causing your issue.
Set that option to a 1 and restart the nrpe agent and see if you can pass arguments with the check_nrpe command.
You always have to restart the nrpe agent if you edit the nrpe,cfg file, BTW.
Also, try running your command like the following and see if that works.
./check_nrpe -H 172.31.116.108 -4 -c check_users -a '5 10'
Change this line (in the nrpe.cfg file) from this:
dont_blame_nrpe=0
to this:
dont_blame_nrpe=1
and restart nrpe service (if nrpe is running as a standalone daemon) or xinet.
Let us know if this helped.
krishnar
Post by krishnar »
Oops..I forgot to mention that earlier..I had already enabled that option and restarted NRPE daemon in remote host after making changes to nrpe.cfg.
[user@krishnar1 etc]$ grep blame nrpe.cfg
dont_blame_nrpe=1
# command arguments *AND* the dont_blame_nrpe directive in this
[user@krishnar1 etc]$ grep command_sub nrpe.cfg
allow_bash_command_substitution=1
From Nagios Core Host:
-bash-4.2$ ./check_nrpe -H 172.31.116.108 -4 -c check_users -a '5 10'
NRPE: Command 'check_users!5 10' not defined
The error says command is not defined.
This is the command definition in remote host nrpe.cfg file.
[user@krishnar1 etc]$ grep check_users nrpe.cfg
#command[check_users]=/usr/local/nagios/libexec/check_users -w 5 -c 10
#command[check_users]=/usr/local/nagios/libexec/check_users -w $ARG1$ -c $ARG2$
Totally confused! :cry: :cry: :cry:
Out of curiosity what version of check_nrpe do you have on your Nagios Core host
./check_nrpe -h|head -7
Post by Box293 »
The ./configure command requires --enable-command-args.
This is explained under the Compile section in this guide: https://support.nagios.com/kb/article.php?id=515
You may also find this document helpful:
https://assets.nagios.com/downloads/nag ... utions.pdf
krishnar
Post by krishnar »
-bash-4.2$ ./check_nrpe -h | head -7
NRPE Plugin for Nagios
Copyright (c) 1999-2008 Ethan Galstad ([email protected])
Version: 3.0.1
Last Modified: 09-08-2016
License: GPL v2 with exemptions (-l for more info)
SSL/TLS Available: OpenSSL 0.9.6 or higher required
-bash-4.2$
