monitoring websites from nagios & check_mk
agroknow
Post by agroknow »
i am new on using nagios. We have install check_mk 1.2.0p2 version so we can monitoring our virtual machines (hosts). Who can monitoring our websites? If we use Nagios XI is a different installation? How can i enable website monitoring in the installation of nagios i already have?
I have search in wato options with no results. As far as i can see nagios provides you with http service monitoring. Is that for websites monitoring?
My problem is that in a virtual machine (host) i have many websites. How can check each one and also check the host of the websites? Is there any plugin i can use?
Thank you in advance,
Jenny
tacolover101
Re: monitoring websites from nagios & check_mk
Post by tacolover101 »
i'm confused what your asking about check_mk - but, as a plugin check_http is probably what your looking for.
http://nagios-plugins.org/doc/man/check_http.html
cdienger
Post by cdienger »
As tacolover101 pointed out, it sounds like check_http is what you need. Let us know if you have any questions after taking a look at documentation that was linked.
agroknow
Post by agroknow »
thank you both for your answers . I add the plugin and add the http service in 2 hosts i wanted. Unfortunate i have another problem. How can i host showing down and all the services are ok and green? Also the specific host- virtual machine is running is not down because i checked it.
What i am doing wrong?
Thank you ;)
Post by mcapra »
Can you show us your host definition as well as the command definition used in the host's check_command directive?
The meat of your question depends on how the host was configured.
cdienger
Post by cdienger »
The host checks uses ICMP pings to determine if they're up or not. The default host check in commands.cfg looks like:
        command_name    check-host-alive
        command_line    $USER1$/check_ping -H $HOSTADDRESS$ -w 3000.0,80% -c 5000.0,100% -p 5
It is possible that the web servers block pings but allow http access. If you have the access, make sure the servers hosting the sites allow ICMP traffic. Another option would be to configure a new command that uses a different method to determine if the host was up. A quick example would be:
        command_name    check-port-80
        command_line    $USER1$/check_tcp -H $HOSTADDRESS$ -p 80
The above command would check to make sure a tcp connection can be made on port 80(default http port).
agroknow
Post by agroknow »
sorry for the late answer. Although the virtual machine are running the host in nagios seem to be down. All services are running and i have only one critical notice .
CRIT fs_/ CRIT - 94.4% used (7.31 of 7.7 GB), (levels at 80.0/90.0%), trend: +7.13MB / 24 hours
The vm is in amazon and i have allowed ICMP traffic.
What else can i do?
thank you
Can you verify that you have allowed inbound ICMP traffic to that host in the AWS security Group as well as the firewall if the OS is running one?
What OS and release is the AWS system running?
agroknow
Post by agroknow »
Hi ,
i have checked more closely the inbounce rules of ICMP and now it is working fine.
Thank you
That is good to hear that it is working now. If you don't have anymore questions, shall I mark the post as solved and lock it up?
