Mass deletion of a service
medleyb
Post by medleyb »
I have a service assigned to hundreds of virtual machines. Short of deleting each service one-by-one from each host, how do I more easily do a mass deletion of a service?
Re: Mass deletion of a service
Post by mcapra »
If the services are a Service->Host relationship, and the services share the same "Service Description" you should be able to do that through the Core Config Manager with a simple search. In this example, i'm using "PING":
