After funning the fullinstall script and conencting to x.x.x.x/nagiosfusion i get the error message
DB Connect Error [nagiosfusion]: Database connection failed
when i try and manualy run the create_postgres_db.sh i get the error
psql: FATAL: database 2Roor" does not exits
The XI server im trying to install fusion onto is a VM runnign a fresh VM image of XI
IS anyone able to advise me what i will be doing wrong?
32bit Centos VM image from XI downlaod page running on winodws7 64bit on AMD Phenom II x6 1057T
Re: DB Connect Error [nagiosfusion]: Database connection fai
What version of CentOS is this running on?
There have been some repo changes lately that have been causing a lot of headaches for our install scripts. Can you also check to see if postgresql is running (or was installed at all)?
service postgresql restart
