Nagios Log server Installation Error
premnath
Post by premnath »
Hi
I am premnath, we have 8 servers with centos 6.7 & 7.2
i have installed Nagios Log server in both versions while i run " fullinstall " scripts. It results with the Installation Error as shown below.
Error: exim conflicts with sendmail-8.14.7-4.el7.x86_64
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
INSTALLATION ERROR!
in your communications with Nagios Enterprises technical support.
The step that failed was: 'prereqs'
Can any one support me in this issue.
--Premnath
Re: Nagios Log server Installation Error
Post by mcapra »
Are these clean, minimal systems built using the minimal CentOS ISO? Nagios Log Server must be installed on a clean, minimal version of CentOS / RHEL.
premnath
Post by premnath »
Thanks for your reply.
Yes the servers are built with minimal version of CentOS.
Thanks & Regards
Premnath.J
cdienger
Post by cdienger »
It appears the exim package is already installed on the "clean" system. Remove it first with "yum remove exim" and run the fullinstall script again.
