HTTP WARNING: HTTP/1.1 400 Bad Request
Hi ! Have strange request from check_http after configure
/usr/local/nagios/libexec/check_http portal.work.com
HTTP WARNING: HTTP/1.1 400 Bad Request - 391 bytes in 0.745 second response time |time=0.744530s;;;0.000000 size=391B;;;0
I know theare load balancer, how can i configure correcct command ?
Re: HTTP WARNING: HTTP/1.1 400 Bad Request
Can you run check_http with verbose output (-v) enabled and share the (sanitized) output? It may offer some clues:
Does this portal have a specific port that needs to be used other than 80/443?
/usr/local/nagios/libexec/check_http portal.work.com -vFormer Nagios employee
mcapra wrote:Can you run check_http with verbose output (-v) enabled and share the (sanitized) output? It may offer some clues:
Does this portal have a specific port that needs to be used other than 80/443?Code: Select all
root@web01:~# /usr/local/nagios/libexec/check_http portal.work.com -v
GET / HTTP/1.0
User-Agent: check_http/v2.1.4 (nagios-plugins 2.1.4)
Connection: close
Accept: */*
http://portal.work.com:80/ is 391 characters
STATUS: HTTP/1.1 400 Bad Request
**** HEADER ****
Server: nginx
Date: Fri, 14 Apr 2017 03:25:29 GMT
Content-Type: text/html; charset=iso-8859-1
Content-Length: 226
Connection: close
**** CONTENT ****
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>400 Bad Request</title>
</head><body>
<h1>Bad Request</h1>
<p>Your browser sent a request that this server could not understand.<br />
</p>
</body></html>
HTTP WARNING: HTTP/1.1 400 Bad Request - 391 bytes in 0.503 second response time |time=0.503225s;;;0.000000 size=391B;;;0
- Former Nagios Staff
Is this a public website? Can you pm the URL so that we can test? If you pm make sure you update this thread so it comes back up on our portal.
UPDATE: addresses shared with techs
Reason: pm received
Reason: pm received
Send you pm, please check.dwhitfield wrote:Is this a public website? Can you pm the URL so that we can test? If you pm make sure you update this thread so it comes back up on our portal.
You need a -H before the host. Note also the difference if you use -S versus not using it.
[root@centos7x64 scripts]# /usr/local/nagios/libexec/check_http -H portal.com -S
HTTP OK: HTTP/1.1 200 OK - 10029 bytes in 1.521 second response time |time=1.520601s;;;0.000000 size=10029B;;;0
HTTP OK: HTTP/1.1 301 Moved Permanently - 368 bytes in 1.545 second response time |time=1.544647s;;;0.000000 size=368B;;;0
I reconfigure my .cfg file, changedwhitfield wrote:You need a -H before the host. Note also the difference if you use -S versus not using it.
[root@centos7x64 scripts]# /usr/local/nagios/libexec/check_http -H portal.com -S HTTP OK: HTTP/1.1 200 OK - 10029 bytes in 1.521 second response time |time=1.520601s;;;0.000000 size=10029B;;;0 [root@centos7x64 scripts]# /usr/local/nagios/libexec/check_http -H portal.com HTTP OK: HTTP/1.1 301 Moved Permanently - 368 bytes in 1.545 second response time |time=1.544647s;;;0.000000 size=368B;;;0
check_commandCode: Select all
check_httpCode: Select all
check_http!-HSCode: Select all
HTTP OK: HTTP/1.1 301 Moved PermanentlyRe: HTTP WARNING: HTTP/1.1 400 Bad Request
Try using the -f follow option:
/usr/local/nagios/libexec/check_http -H portal.work.com -f followRe: HTTP WARNING: HTTP/1.1 400 Bad Request
change tossax wrote:Try using the -f follow option:
check_http!-H!-f followRe: HTTP WARNING: HTTP/1.1 400 Bad Request
The command should look like this:
command_name check_http
command_line $USER1$/check_http -H $HOSTADDRESS$ $ARG1$
and then the check command:
check_command check_http!-f follow
