Hi all,
I want't to run Foreman + Nagios Core on the same server. When i install both, i can only acces Foreman via the Webinterface. For both to be accessible via the webinterface i need to configure Virtualhosts (i guess). Can someone explain how to accomplish this so that Foreman and Nagios can be reachable both. So it needs to be example.com/nagios and example.com/foreman
Thank you in advance.
*Httpd Nagios.conf attached*
Nagios VirtualHost configuration
nagios.conf.txt- Httpd Nagios.conf
- (1.64 KiB) Downloaded 424 times
Re: Nagios VirtualHost configuration
That's a bit out of scope, but to even begin we would need to see literally every Apache configuration file being loaded to make sense of what's happening. Not just the Nagios ones. Are you able to provide those?
