trial limits
eltrasimaco
trial limits
Post by eltrasimaco »
I've read the nagiosxi trial version is fully functional up to 60 days; but I remember someone wrote somewhere that some or all of the enterprise funcionalities weren't available, is this true?
TIA
Re: trial limits
Post by dwhitfield »
Enterprise functionality is a separate 60-day trial. You can turn that on from any page that requires a post-trial enterprise account.
Reason: clarification
eltrasimaco
Re: trial limits
Thanks for your quick response, but unfortunately I dont understand it well; as long as I know, after reading the docs, it is not possible to access any of the enterprise features in the 60-day trial version; am i wrong?
TIA
Re: trial limits
I have attached a screenshot in which you can see that the regular trial and the enterprise trial are separate. Once your enterprise trial is over, you will not have access to those features.
eltrasimaco
Re: trial limits
So there are separated downloads, one for standard trial AND another for enterprise trial, or you activate one or the other on installation?
Re: trial limits
If you go to http://YOURSERVER/nagiosxi/admin/license.php then you'll see the place to enable enterprise features.
It is not a separate download.
eltrasimaco
Re: trial limits
OK now i got it, thanks!
Re: trial limits
Great! Ready to lock the thread?
