NRPE: Unable to read output
nagiostool
Post by nagiostool »
Hi when i'm using NRPE i'm getting the folowing error
the commands its using are
check_nrpe!check_disk!-a '-w 20% -c 10% -p /'
check_nrpe!check_open_files!-a '-w 30 -c 50'
check_nrpe!check_swap!-a '-w 50 -c 20'
check_nrpe!check_procs!-a '-w 150 -c 250'
check_nrpe!check_users!-a '-w 5 -c 10'
For all the above commands i'm getting the same error
Please help me out
Re: NRPE: Unable to read output
What happens when you run the command from the command line, for example:
# cd /usr/local/nagios/libexec
# ./check_nrpe -H <your_target_machine_IP_address> -c check_disk -a '-w 20% -c 10% -p /'
What about the output of this:
# ./check_nrpe -H localhost
and
Run on the client (target machine):
# service xinetd restart
# tail /var/log/messages
and post the output.
epx998
Post by epx998 »
Did you run the NRPE agent install on the host to be monitored?
Yes, you install the NRPE agent on the client (target machine). Here is the document you need to look at:
http://library.nagios.com/library/produ ... inux-agent
If you ran the installer, but got some errors (dependencies, etc.), you can re-run it. By the end of the installation, you will be asked to enter the IP of you Nagios server.
Hope this helps.
nagiostool
output is NRPE: Unable to read output
Output is NRPE v2.12
nagiostool
lmiltchev wrote:Yes, you install the NRPE agent on the client (target machine). Here is the document you need to look at:
Hope this helps.
Thanks your suggestion has worked but does this working for Unregistered RHEL 4.0 ??
I have test machine with RHEL 4.0 (unregistered) , thinking to give a try does it work ???
mguthrie
Post by mguthrie »
I'm pretty sure you'll need to register with RHN, the package requires the use of "yum update."
