Action Component script - is the user available to my script
Testing a script to be executed via Components Action Command. I'd like to capture the username of the nagios user that clicked on the action (in my script). Is this possible?
Re: Action Component script - is the user available to my sc
Possible? Probably, but the work would be non-trivial. You could grab the cookie's nagiosxi value and reverse engineer that against the PHP session data (in /var/lib/php/session/sess_<nagiosxi_val_from_cookie>).
Another option would be to use some clever jQuery to pass the username in the top-left corner of the page off to the script via arguments.
SteveBeauchemin
Doesn't Quick Actions have a user parameter that shows who is the current logged in user?
Maybe try having this passed to your script at some point.
Admin menu / Manage Components / Actions --> settings
Add it to your URL / Command: line
Update your script to read it.
You cannot capture the user name, but you can pass it to the script.
That is how I do it.
Steve B
%username%Add it to your URL / Command: line
Steve B
XI 5.7.3 / Core 4.4.6 / NagVis 1.9.8 / LiveStatus 1.5.0p11 / RRDCached 1.7.0 / Redis 3.2.8 /
SNMPTT / Gearman 0.33-7 / Mod_Gearman 3.0.7 / NLS 2.0.8 / NNA 2.3.1 /
NSClient 0.5.0 / NRPE Solaris 3.2.1 Linux 3.2.1 HPUX 3.2.1
Sure enough, you're correct! The work is actually pretty trivial, as it turns out. From the component:
So your command might look like this:
// Try getting the user
$username = get_user_attr(0, "username");
if (empty($username))
$username = "UNKNOWN_USER";
php -q /tmp/user.php %username%Former Nagios employee
Thank you, all I had to do was pass %username% to my script as you said Steve. The doc I was using only mentioned the Host and Service Macros available to Actions component.
Did you have any additional questions on this topic?
No, all good, thanks
