I installed the agent on multiple servers. On one, the ./fullinstall script seems to have installed both xinetd version AND the standalone, and so they are conflicting trying to use the same port. What commands would I use to uninstall ONLY the standalone?
Environment:
Ubuntu 16.04
Thanks in advance!
Uninstall standalone NRPE
Re: Uninstall standalone NRPE
You could either remove the xinetd configuration for nrpe (/etc/xinetd.d/nrpe) or remove the init.d script for nrpe. Both of those things leverage the exact same binary, they just do it in different ways.
- tacolover101
a handy tool i've found is locate, which might help you -
apt-get install mlocate
let it finish... then run...
updatedb
now let's make this easy to find the NRPE files...
locate nrpe
Thanks tacolover101. InscrutableDude, did the above help?
