Configuration Wizard Network Switch Missing
brdr
Post by brdr »
Hi Nagios,
We just upgraded from XI 5.2.2 to 5.4.3. I noticed after the upgrade the Network Switch / Router wizard disappeared.
The folder (below) exists on the XI server. And I compare the contents of this directory to another XI environment that was upgraded and see the wizard fine within the UI.
/usr/local/nagiosxi/html/includes/configwizards/switch
How can I get the wizard back from the environment it is missing from?
Re: Configuration Wizard Network Switch Missing
You could download it using the link below to your PC.
https://assets.nagios.com/downloads/nag ... switch.zip
Then in the Admin > Manage Config Wizards menu, browse to it and upload it to the server.
Try that and post if you have any issues doing this.
brdr
Post by brdr »
Thx. All set. plz close.
