Problem with notification alerts when bw is below threshold
digea
Post by digea »
We have trouble configuring notification alerts for our bandwidth monitoring services for our Cisco switches for the cases where we want to get a critical or warning alert when bandwidth goes below a threshold.
An example:
According to https://nagios-plugins.org/doc/guidelines.html, if want Nagios to trigger a warning notification when input bw goes below 62 Mbps and a critical notification when it goes further down below 50 Mbps, we have to use a check command like this:
check_xi_service_mrtgtraf!192.168.xxx.xxx_10101.rrd!62.0:,500.0!50.0:,800.0!M!!!!
This is how input/output gauges look like in this case and when input bw is ~60Mbps:
Although current input bw is within the warning range, service state remains in the OK state:
We've tried several different combinations of the alert tresholds, but we couldn't manage to have a state other than OK.
Are we missing something here?
Thank you in advance.
IP Team
DIGEA S.A
[email protected]
cdienger
Re: Problem with notification alerts when bw is below thresh
Post by cdienger »
Hi Digea,
I believe what you want is:
[email protected]:62.0:!50.0:!M
Give this a shot and let me know your results.
digea
Post by digea »
I tried what you suggested but with no success. Any suggestions on how I could possibly debug this?
IP Team
DIGEA S.A
[email protected]
cdienger
Post by cdienger »
Unfortunately after poking around this a bit more, the plugin only triggers if bandwidth exceeds a threshold. You can try using check_snmp instead. See rkennedy's post at https://support.nagios.com/forum/viewto ... =7&t=41640 for details.
