hi
I need help to configure 3par storage with Nagios xi
need steps and need plugins
BR
3 par storage with Nagios xi
Re: 3 par storage with Nagios xi
Hi Paltel,
These should be good starting points:
https://exchange.nagios.org/directory/P ... pt/details
https://github.com/qaxi/nagios-check_3par
https://exchange.nagios.org/directory/P ... me/details
Dear Cdienger
this is to inform you that we found the scripts on Nagios forum ,but we need technical engineer to connect with us via remote session like WebEx in order to add the 3PAR monitoring script to current scripts in Paltel Nagios system,
please consider this request as high priority
thanks
Firas
thanks
Firas
We generally will not resort to a remote session as a first line of support. What troubles are you having specifically with the plugins? Are they giving any errors?
In addition to what tmcdonald said, it would be helpful if you reviewed our document on managing plugins in Nagios XI. It will teach you how to test plugins from the command line, and how to create new commands, and services in Nagios XI.
Let us know if you get stuck on something.
