I followed the Nagios XI-How to Integrate SNMP traps with Nagios XI
https://assets.nagios.com/downloads/nag ... 1452024033
I am seeing traps coming into my nagios system /var/log/snmptrapd.log * i created a rule in rsyslog to throw snmptrad stuff there .
However im not getting Nagios XI to show me its processing the traps .
After running the wizard for a switch that is already being monitored all i get is Waiting for trap... *been like that for 2 days.*
And i see where i have yet to install the correct MIB for a trap and my /var/log/snmptt/snmpttunknown.log is quite large..
My juniper switches can send bogus traps to test
run request snmp spoof-trap linkDown variable-bindings "ifIndex[116]=116, ifAdminStatus[116]=1 ,ifOperStatus[116]=2 , ifName[116]=ge-0/0/0"
and i see the trap show up in /var/log/snmptrapd.log
May 1 07:53:48 dragon snmptrapd[29649]: 2017-05-01 07:53:48 <UNKNOWN> [UDP: [10.3.254.15]:62492->[157.182.94.79]]:#012DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (92935263) 10 days, 18:09:12.63#011SNMPv2-MIB::snmpTrapOID.0 = OID: IF-MIB::linkDown#011IF-MIB::ifIndex.116 = INTEGER: 116#011IF-MIB::ifAdminStatus.116 = INTEGER: up(1)#011IF-MIB::ifOperStatus.116 = INTEGER: down(2)#011IF-MIB::ifName.116 = STRING: ge-0/0/0
I see the trap made it to /var/log/snmptt.log
Mon May 1 07:53:48 2017 .1.3.6.1.6.3.1.1.5.3 Normal "Status Events" 10.3.254.15 - Link down on interface 116. Admin state: up. Operational state: down
In my /etc/snmp/snmptt.conf i do not see any EXEC set to run the .py script.. So followed the sed replacement KB https://support.nagios.com/kb/article.php?id=559
I never see anything in my /usr/local/nagios/var/nagios.log showing a trap was sent to be processed by the py script . I do get
[1493524800] CURRENT SERVICE STATE: 2260-ex3400;SNMP Traps;OK;HARD;1;Waiting for trap...
Can you please help me fill in the gap im having ?
SNMP traps not updating XI
avandemore
Re: SNMP traps not updating XI
In the first document you cited, did you follow the section on Unconfigured Objects? If not, this could explain your symptoms.
Previous Nagios employee
You nailed it avandenmore. Im sorry I could have swore I did RTFM . You got me working. I will re read the pdf and say
- Former Nagios Staff
In an effort to improve our documentation, is there anything you would suggest so people don't unintentionally skip a key section?
