Configure nslog.conf for DFSR logging
james.liew
Post by james.liew »
Hi all,
I'm trying to configure the nslog client to log for DFSR replication. Like below.
I'm having trouble determining the exact Syntax to use :(
Can I just add <Select Path="DFS Replication">*</Select>\ in the query list?
This is my current query list:
Query  <QueryList>\
                       <Query Id="0">\
                         <Select Path="System">*</Select>\
                         <Select Path="Application">*</Select>\
			<Select Path="Security">*</Select>\
                        </Query>\
              </QueryList>
Re: Configure nslog.conf for DFSR logging
Post by mcapra »
That's what this example seems to be doing:
https://gist.github.com/grenade/3bbb336209a8859af9d1
<Input filtered_eventlog>
  Module im_msvistalog
  ReadFromLast TRUE
  Query <QueryList>\
          <Query Id="0">\
            <Select Path="Application">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="System">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="Active Directory Web Services">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="DFS Replication">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="Directory Service">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="HardwareEvents">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="Internet Explorer">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="Key Management Service">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="Microsoft-Windows-Application Server-Applications/Admin">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="Microsoft-Windows-Dhcp-Client/Admin">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="Microsoft-Windows-DhcpNap/Admin">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="Microsoft-Windows-Dhcpv6-Client/Admin">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="Microsoft-Windows-Diagnosis-Scripted/Admin">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="Microsoft-Windows-EnrollmentPolicyWebService/Admin">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="Microsoft-Windows-EnrollmentWebService/Admin">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="Microsoft-Windows-Kernel-EventTracing/Admin">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="Microsoft-Windows-MUI/Admin">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="Microsoft-Windows-PrintService/Admin">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="Microsoft-Windows-RemoteApp and Desktop Connections/Admin">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="microsoft-windows-RemoteDesktopServices-RemoteDesktopSessionManager/Admin">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="Microsoft-Windows-TerminalServices-ClientUSBDevices/Admin">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="Microsoft-Windows-TerminalServices-LocalSessionManager/Admin">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="Microsoft-Windows-TerminalServices-PnPDevices/Admin">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="Microsoft-Windows-TerminalServices-RemoteConnectionManager/Admin">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="ThinPrint Diagnostics">*[System[Level=1 or Level=2 or Level=3]]</Select>\
            <Select Path="Windows PowerShell">*[System[Level=1 or Level=2 or Level=3]]</Select>\
          </Query>\
        </QueryList>
</Input>
I imagine adding an additional <Select> should be sufficient.
james.liew
Seems to be working after I added that line.
Will monitor for now
Post by dwhitfield »
Fantastic. No need to respond if it ends up working, but do let us know if you continue to have problems.
