Query Regrding Monitoring NetApp Storage With Nagios
ramesh.mohite
Post by ramesh.mohite »
Dear Team,
We have deployed Nagios Core in our environment and have query regarding monitoring NetApp storage. Is it possible to monitor Netapp stoarge with Nagios Core? our requirement is monitoring disk status, volume / aggregate space status, Snapmirror / Snapshot status, Performance, Disk utilization, IOPS etc.
Please help me with this query.
Thanks in advance.
Re: Query Regrding Monitoring NetApp Storage With Nagios
Post by mcapra »
ramesh.mohite wrote:Is it possible to monitor Netapp stoarge with Nagios Core?
Nagios Core can monitor practically anything that you can write a script/binary for. Here's a few different plugins that people have written to help with monitoring NetApp storage:
https://exchange.nagios.org/index.php?o ... ord=NetApp
rhassing
Post by rhassing »
It is possible to monitor it all using snmp.
The main problem is the load on the Netapp if you using SNMP too much. we are collecting data using Grafana and using Nagios for monitoring.
We are more and more thinking to either use the Grafana data to do monitoring as well, or make sure we do some sort of caching to collect "static" data and put that in a database and check regularly if the data is still correct.
Is it a normal Netapp appliance, or a clustered environment you want to monitor?
Rob Hassing
Thanks @rhassing for the help.
@ramesh.mohite, if you have any further questions, just post them and we'll try and help.
ramesh.mohite
Thanks Rob & tgriep....
Can we use nagios plugins in Nagios core? Or we need to purchase commercial support?
Can these plugins work with all netapp model?
We want to monitor 7 mode as well as cluster mode appliance.
Post by mcapra »
Any plugin written for use in Nagios Core or Nagios XI can be used in either software. There are some components/graphics that are specific to Core/XI, but the plugins should all work for Core.
You should be able to use those plugin in Nagios Core and they are free to use.
You would have to search the exchange site for the Netapp plugins and see if there are any details in what they do as well as the Models they support.
Take a look at these links to see if this is what you are looking for to monitor on your devices.
https://exchange.nagios.org/directory/P ... de/details
https://exchange.nagios.org/directory/P ... p3/details
https://exchange.nagios.org/directory/P ... 29/details
https://exchange.nagios.org/directory/P ... ap/details
