Top 10 terms in field clienip show 'other values'
ouyangxin
Post by ouyangxin »
Hi All,
my nagios log server client ip show 'Other values', but there is not any values but IP. So how to ignore or find out this values?
thanks
Re: Top 10 terms in field clienip show 'other values'
Post by mcapra »
Are you referring to this?
Often when you create panels in Kibana, you do so with a maximum "length" in mind. In the above case, the maximum length is 10 so it shows the top 10 most occurring entries then lumps everything else under "Other values".
Increasing this value will subsequently increase the number of results displayed:
If you wanted to list everything, set the limit to some absurdly high number.
