Logical Drive '/dev/' [RAID-0, 1,862.50 GB] is Ready
vivekraghuwanshi
Post by vivekraghuwanshi »
Hi ,
My nagios server is sending alerts "Logical Drive '/dev/sdj' [RAID-0, 1,862.50 GB] is Ready". when i check with dell tolls there is nothing wrong with Harddrive, please help us how i can fix it.
I am using check_openmanage to check hard disk status.
Harddisks are arranged in RAID 0,JBOD
Re: Logical Drive '/dev/' [RAID-0, 1,862.50 GB] is Ready
Post by dwhitfield »
Is it sending notifications or just displaying that information on the status screen? What color is the status? If you are getting unwanted notifications, you can turn them off. I think https://assets.nagios.com/downloads/nag ... ml#service will be of use.
What version of Core are you using? Was it compiled from source or installed from distro repos? On what OS/version is nagios running? cat /etc/*-release may be of use. Once I know if it was compiled or not, I will be more likely to be able to tell you where your service definitions are located so that you can turn off the notifications.
