nagios xi not working after install of nna
newkid
Post by newkid »
I installed the Nagios network analyzer on the same server running xi server.....xi server start but I get an error 500 shortly after entering.
x.x.x.x is currently unable to handle this request.
HTTP ERROR 500
I installed nna with:
cd /tmp
wget http://assets.nagios.com/downloads/nagi ... est.tar.gz
tar xzf nagiosna-latest.tar.gz
cd /tmp/nagiosna
./fullinstall
Re: nagios xi not working after install of nna
Post by dwhitfield »
You can't do that. They need to be on separate machines (virtual machines will work). Your quickest resolution will be to revert to a snapshot. If you don't have a snapshot, depending on how far along you are in XI, it might be quicker to just start over from scratch.
This is not to say this is the only way, but there will be a log of permissions to correct in the process.
If you still have your XI installer in /tmp/nagiosxi, you could just run ./upgrade and see if it fixes the permissions issues.
Alternatively, what's the output of ll -R /usr/local? You'll need to probably put that in a text file and attach it. Alternatively, you could put it in a code block.
UPDATE: ls info sent in PM.
please run the following
cd /tmp/nagiosxi
./upgrade
Reason: additional info after pm received
