Getting error check_esx3.pl
bosecorp
Post by bosecorp »
MOD EDIT: Split from https://support.nagios.com/forum/viewtopic.php?t=43822 as this is a new check
Need help in setting the right thresholds now..
# /usr/local/nagios/libexec/check_esx3.pl -H "xx.xx.xx.xx" -f "/usr/local/nagiosxi/etc/components/vmware/xxxxx04_bose_com_auth.txt" -l "VMFS" -s xx-App_1 -w10%: -c5%:
ESX3 OK - xx-App_1=333605.00 MB (15.91%) | xx-App_1=15.91%;10:;5:
The requirement here is that , if the free space value (highlighted in red) goes below
100-11% should report ok
10-6% its should report as warning
5-0% then critical,
Can you please help me setting the thresholds as mentioned above
Reason: adding link back
bosecorp
Re: Getting error check_esx3.pl
Post by bosecorp »
can someone assist me with this ?
Post by dwhitfield »
It says ok at 15, which is what you want. Am I missing something?
bosecorp
Post by bosecorp »
Kindly ignore the output mentioned in the output, seems like i'm not entering the right parameters.
Lets say the output is 15%, ideally it should say as ok, as per below conditions.
5-0% then critical
I was going through the thresholds mentioned in the link https://nagios-plugins.org/doc/guidelines.html
But was not able to get the right parameters here.
bosecorp
Post by bosecorp »
# /usr/local/nagios/libexec/check_esx3.pl -H "xx.xx.xx.xx" -f "/usr/local/nagiosxi/etc/components/vmware/xx_bose_com_auth.txt" -l "VMFS" -s dce-App_21 -w12%: -c5%:
ESX3 WARNING - dce-App_21=212914.00 MB (10.15%) | dce-App_21=10.15%;12:;5:
# /usr/local/nagios/libexec/check_esx3.pl -H "xx.xx.xx.xx" -f "/usr/local/nagiosxi/etc/components/vmware/xx_bose_com_auth.txt" -l "VMFS" -s dce-App_9 -w10%: -c5%:
ESX3 CRITICAL - dce-App_9=9247.00 MB (0.44%) | dce-App_9=0.44%;10:;5:
# /usr/local/nagios/libexec/check_esx3.pl -H "xx.xx.xx.xx" -f "/usr/local/nagiosxi/etc/components/vmware/xx_bose_com_auth.txt" -l "VMFS" -s dce-App_14 -w10%: -c5%:
ESX3 OK - dce-App_14=235686.00 MB (11.24%) | dce-App_14=11.24%;10:;5:
Looks like its working correct. Can you confirm this one?
It looks like all of those check out. Did you want to close the thread or did you have other questions?
