Hello
I am in process of implementing Nagios monitoring across 100+ AIX nodes. I am looking for tips on the following
1. Can I have a Nagios NRPE scripts running as different user id? e.g. (xs_nagios)
2. Also would like this user to be a LDAP user-id, mean's I don't have to create a user/group on each AIX server
Some pointers in the right direction would be very helpful
Regards
Sasi Chand
Nagios User id on remote Servers
- Former Nagios Staff
Re: Nagios User id on remote Servers
1. Yes. On about line 54 of nrpe.cfg (depending on your version). Be sure to read the commends before that setting.
2. This question is best suited for your AIX administrator. It looks like this should be possible though: https://www.ibm.com/developerworks/aix/ ... tegration/
Hello there
Thanks very much.
Regards
Thanks very much.
Regards
Did you have any other questions or are we ready to lock this up?
