WebSphere plugin
hsauerbach
WebSphere plugin
I am trying to get the Nagios plugin for WAS monitoring running on a Linux client with no luck. I am running 1.7, jreand WebSphere 8.5.0 and complied the was agent.jar. Did Step by Step following the documentation at https://github.com/yannlambret/webspher ... s#features with no luck. Any help would be very appreciated.
Re: WebSphere plugin
No one here designed that plugin, so the assistance we can offer may be limited.
Can you share the sorts of errors/outputs you are encountering at each stage of the steps mentioned in the github's readme? We don't really have much to work with in terms of troubleshooting currently.
I tend to direct people towards enabling JMX on their applications. You'd have to consult with your application team to accomplish that, though.
hsauerbach
For each JVM being monitored, were enabled in the WebSphere console.
everything configured fine including compiling the "build.xml" using ant and 1.7 jre to produce was agent.jar.
When I ran run.sh I got the following:
[/usr/local/wasagent]# ./run.sh
++ dirname ./run.sh
+ cd .
+ JAVA_HOME=/opt/WebSphere85/AppServer/java_1.7_64/
+ JAVA_OPTS='-Dwasagent.host=127.0.0.1 -Dwasagent.port=9090 -Dwasagent.configuration=wasagent.properties'
+ CLASSPATH=.:wasagent.jar
++ find lib -name '*.jar'
+ for jar in '$(find "lib" -name '\''*.jar'\'')'
+ CLASSPATH=.:wasagent.jar:lib/jetty-servlet-7.6.2.v20120308.jar
+ CLASSPATH=.:wasagent.jar:lib/jetty-servlet-7.6.2.v20120308.jar:lib/com.ibm.ws.security.crypto.jar
+ CLASSPATH=.:wasagent.jar:lib/jetty-servlet-7.6.2.v20120308.jar:lib/com.ibm.ws.security.crypto.jar:lib/com.ibm.ws.admin.client_8.5.0.jar
+ CLASSPATH=.:wasagent.jar:lib/jetty-servlet-7.6.2.v20120308.jar:lib/com.ibm.ws.security.crypto.jar:lib/com.ibm.ws.admin.client_8.5.0.jar:lib/com.ibm.ws.webservices.thinclient_8.5.0.jar
+ CLASSPATH=.:wasagent.jar:lib/jetty-servlet-7.6.2.v20120308.jar:lib/com.ibm.ws.security.crypto.jar:lib/com.ibm.ws.admin.client_8.5.0.jar:lib/com.ibm.ws.webservices.thinclient_8.5.0.jar:lib/servlet-api-2.5.jar
+ /opt/WebSphere85/AppServer/java_1.7_64//bin/java -Xmx16m -cp .:wasagent.jar:lib/jetty-servlet-7.6.2.v20120308.jar:lib/com.ibm.ws.security.crypto.jar:lib/com.ibm.ws.admin.client_8.5.0.jar:lib/com.ibm.ws.webservices.thinclient_8.5.0.jar:lib/servlet-api-2.5.jar -Dwasagent.host=127.0.0.1 -Dwasagent.port=9090 -Dwasagent.configuration=wasagent.properties net.wait4it.nagios.wasagent.core.WASAgent
When I executed the was agent.sh script with debugging turned on I got the following:
[/usr/local/wasagent]# ./wasagent.sh 'hostname=ssc-prd-dmav1-016.ba.ssa.gov&port=8882&jvm=heapUsed,90,95'
+ HOST=127.0.0.1
+ CONNECTOR=9090
++ wget -O - http://127.0.0.1:9090/wasagent/WASAgent '--post-data=hostname=XXX&port=8882&jvm=heapUsed,90,95'
+ DATA=
+ '[' 8 '!=' 0 ']'
+ exit 2
I received no data. I also know the JVM's are enabled because we run Introscope on the server. All the work was done on the Nagios Client.
Any and all help would be VERY appreciated. I need to prove this work for us to make a large purchase.
++ dirname ./run.sh
+ cd .
+ HOST=127.0.0.1
+ CONNECTOR=9090
+ DATA=
+ '[' 8 '!=' 0 ']'
+ exit 2
- Former Nagios Staff
We can't guarantee we can get a plugin to work that we didn't create. However, we can certainly give it a shot. Have you signed up for a quickstart yet? https://www.nagios.com/services/quickstart/nagios-xi/
Also, have you tried any of the other websphere plugins at https://exchange.nagios.org/directory/P ... /Websphere ?
hsauerbach
We already had a quickstart hour presentation and sorry to say it did not work out to well.
From the list of WebSphere plugins Wasagent is the one we are trying to make work and the only other one that might be OK is WebSphere Application Server -- WebSite https://code.google.com/archive/p/nagios-was/ which we have not tried.
MQ is a product under WebSphere which we don't use anymore so all their plugins don't help us.
Thanks for all your help. It is really important to get something working.
Back to this point:
You could likely do the same wherever your applications are currently being started. I'm not a WebSphere guy though; Most of my Java development is OSS and won't pay for a license
With that, I was able to use the check_jmx plugin quite handily to get some of the more basic MBeans without issue:
Straight JMX really is the way to go with any sort of Java application monitoring, in my opinion. A lot of the various agents tend to get left alone for several years and become ineffectual with how often Oracle likes to change things. JMX on it's own is pretty bare-bones. We also have some documentation for JMX monitoring specifically whereas we do not have documentation specific to JBoss, Tomcat, WebLogic et al.
If you only want to accept JMX connections made locally for security reasons, just run check_jmx through an agent like NRPE or NCPA.
I actually did this for a WebLogic server recently. I'm not sure what sort of applications your WebSphere is hosting, but all I had to do for WebLogic was modify my application's start script to include the following system properties related to JMX:mcapra wrote:I tend to direct people towards enabling JMX on their applications. You'd have to consult with your application team to accomplish that, though.
-Dcom.sun.management.jmxremote
-Djava.rmi.server.hostname=192.168.67.95
-Dcom.sun.management.jmxremote.port=9010
-Dcom.sun.management.jmxremote.local.only=false
-Dcom.sun.management.jmxremote.ssl=false
-Dcom.sun.management.jmxremote.authenticate=falseWith that, I was able to use the check_jmx plugin quite handily to get some of the more basic MBeans without issue:
[root@xi-stable ~]# /usr/local/nagios/libexec/check_jmx -U service:jmx:rmi:///jndi/rmi://192.168.67.95:9010/jmxrmi -O java.lang:type=Memory -A HeapMemoryUsage -K used -I HeapMemoryUsage -J used -vvvv -w 4248302272 -c 5498760192
JMX OK HeapMemoryUsage.used=236421728{committed=365953024;init=268435456;max=477626368;used=236421728}https://assets.nagios.com/downloads/nag ... ios-XI.pdf
hsauerbach
This might be the answer let me check it out and I will let you know.
Please do!hsauerbach wrote:I will let you know.
Also, if you want to stick with that original plugin, you might try posting an issue on their github page: https://github.com/yannlambret/websphere-nagios/issues
hsauerbach
I will post my issue on https://github.com/yannlambret/websphere-nagios/issues before I continue to investigate the other java approach.
I just saw this on the other issue on that github:
Please let us know if you need further assistance.
That's not to say the author can't help on your issue, but it does not look like a plugin that is going to get long-term support from the author.Sorry for the late answer. I haven't be using WebSphere for a long time now, and I'm not able to test or validate anything myself. Feel free to open a pull request and I'll be glad to merge your fix.
