server event viewer
bashar.abed
server event viewer
Post by bashar.abed »
we have Nagios XI version 5.4.2 VM ,
Could you advice if Nagios can read and send the errors appeared on windows server event viewer ??
Kindly check the below screenshot for example as attached file
Re: server event viewer
Post by dwhitfield »
I'm sure there's more than one way to do this, but here are instructions using WMI: https://support.nagios.com/kb/article.php?id=170
