NRPE: Command 'check_memory' not defined
propatience
Post by propatience »
Moderator Edit: This thread has been split from another - https://support.nagios.com/forum/viewto ... =7&t=10772
In the future, please create a new thread and link to the old one instead of adding on.
Hi!
I just wanted to post a reply here because when I looked briefly over the Google results I found nothing saying anything about what was our solution to a "NRPE: Command '...' not defined" problem. We're running Nagios on some Windows Server 2012 R2 machines and our problem resulting in a "NRPE: Command '...' not defined" was that the "check name" was too long.
Ex.
command[XXXX_XXXXXXXXXXXXXX_RDP_TCP_3389]="X:\...\check_tcp.exe" -H XXX.XXX.XXX.XXX -p 3389 -w 10 -c 1000
would not work for us but
command[XXXX_XXXXXXXXXXXXX_RDP_TCP_3389]="X:\...\check_tcp.exe" -H XXX.XXX.XXX.XXX -p 3389 -w 10 -c 1000
would work.
I'm sorry that this isn't specifically about the 'check_memory' check and apologize for that, though I hope this helps someone.
Have a really nice day!
Anton Thelander
Re: NRPE: Command 'check_memory' not defined
Thanks for posting your findings. If it is alright, shall I close and lock up the post for you?
