Help
Chencho
Help
Post by Chencho »
I need help with that, so i install the nagios XI but in the terminal show me these
[root@localhost tmp]# wget http://assets.nagios.com/downloads/nagi ... est.tar.gz
--2017-05-19 13:13:27-- http://assets.nagios.com/downloads/nagi ... est.tar.gz
Resolviendo assets.nagios.com (assets.nagios.com)... 72.14.181.71, 2600:3c00::f03c:91ff:fedf:b821
Conectando con assets.nagios.com (assets.nagios.com)[72.14.181.71]:80... conectado.
Petición HTTP enviada, esperando respuesta... 301 Moved Permanently
Localización: https://assets.nagios.com/downloads/nag ... est.tar.gz [siguiendo]
--2017-05-19 13:13:27-- https://assets.nagios.com/downloads/nag ... est.tar.gz
Conectando con assets.nagios.com (assets.nagios.com)[72.14.181.71]:443... conectado.
Localización: https://assets.nagios.com/redirects/red ... est.tar.gz [siguiendo]
--2017-05-19 13:13:28-- https://assets.nagios.com/redirects/red ... est.tar.gz
Reutilizando la conexión con assets.nagios.com:443.
Petición HTTP enviada, esperando respuesta... 404 Not Found
2017-05-19 13:13:28 ERROR 404: Not Found.
help me i cant install this... thank you!
455157
Re: Help
Post by 455157 »
Ahoy Chencho, welcome to the forum
I think I see the problem, in your initial wget command.
You have:
http://assets.nagios.com/downloads/nagiosxi-latest.tar.gz
but what you actually need is a " / " between nagiosxi and -latest, and xi before the dash like so:
http://assets.nagios.com/downloads/nagiosxi/xi-latest.tar.gz
So, whole command is:
wget http://assets.nagios.com/downloads/nagiosxi/xi-latest.tar.gz
Now, your (server, VM?) will be abled to download the tarball, and you can proceed?
https://support.nagios.com/kb/article/n ... tions.html
Re: Help
Post by dwhitfield »
Thanks @455157!
Additionally, if you want a specific version, you can find them at https://assets.nagios.com/downloads/nag ... rsions.php
