Dear Expert
We using "check_icmp" to monitor the Host, however whenever there is delay (0% packet loss), Nagios considering DOWN. Its not the correct EXIT code.
Nagios should think to resolve this issue.
In OPERATIONS-CENTER, showing DOWN in RED color, which totally wrong, Host is up with high delay, Nagios should not consider its down, should be display in different color (lets say Purple) and should check all the services under it.
We asked Nagios Team to add the feature (host_down_disable_service_checks=1), giving trouble when HOST showing DOWN just because of delay, which is not the correct way.
Regards
host reachable with high delay however Nagios consider DOWN
Re: host reachable with high delay however Nagios consider D
According to the "check_icmp" plugin's usage:
by bumping up the RTA warning/critical values as you have delay issues. Nagios is very flexible product. You can adjust any check to match your environment.
As far as the "host_down_disable_service_checks" directive in the nagios.cfg, it was introduced in Nagios Core 4.1.0.
You can modify the "standard" check:Threshold format for -w and -c is 200.25,60% for 200.25 msec RTA and 60%
packet loss. The default values should work well for most users.
You can specify different RTA factors using the standardized abbreviations
us (microseconds), ms (milliseconds, default) or just plain s for seconds.
/usr/local/nagios/libexec/check_icmp -H <client ip> -w 200.0,40% -c 500.0,100% -p 5As far as the "host_down_disable_service_checks" directive in the nagios.cfg, it was introduced in Nagios Core 4.1.0.
https://www.nagios.org/projects/nagios-core/history/4x/4.1.0 – 08/18/2015
ENHANCEMENTS
Make sticky status for acks and comments configurable enhancement #20 (Trevor McDonald / Scott Wilkerson)
Add host_down_disable_service_checks directive to nagios.cfg #44 (Trevor McDonald / Scott Wilkerson)
Promoted JSON CGIs to released status (Eric Stanley)
New graphical CGI displays: statusmap, trends, histogram (Eric Stanley)
httpd.conf doesn’t support Apache version > 2.3 (DanielB / John Frickson)
