i am using the below configuration for the log based monitoring but there was miss of alarm no alarm was reported for the Postgres down attached are the relevant files.
Can you let me know the reason for such possible miss of alarms from nagiosXI
postgress check is as shown below on the node
[nagios@hnrbt10 conf]$ cat PostgreSQL.conf
$seekfilesdir = '/home/nagios/logfile_basedir/tmp';
$protocolsdir = '/home/nagios/logfile_basedir/tmp';
$scriptpath = '/home/nagios/bin';
#$MACROS = { CL_DISK01 => "/dev/dsk/c0d1", CL_DISK02 => "/dev/dsk/c0d2" };
@searches = (
tag => 'PostgreSQL down',
criticalpatterns => ['PostgreSQL is down'|'PostgreSQL is already stopped'|'Forcing msPostgresql away from hnrbt10 after 1000000 failures'|'Forcing msPostgresql away from hnrbt11 after 1000000 failures'] ,
options => 'sticky=1800,noprotocol,report=long,allyoucaneat',
logfile => '/var/log/messages'
#rotation => 'SUSE',
As i tested it from GUI it gave me the following output PFA
log based monitoring Postgresql
ericssonvietnam
- Former Nagios Staff
Re: log based monitoring Postgresql
Can you attach or PM the postgres logs? I suspect you just need to add a different critical pattern.
Also, can you PM me your Profile? You can download it by going to Admin > System Config > System Profile and click the ***Download Profile*** button towards the top. If for whatever reason you *cannot* download the profile, please put the output of View System Info (5.3.4+, Show Profile if older) in the thread (that will at least get us some info). This will give us access to many of the logs we would otherwise ask for individually. If security is a concern, you can unzip the profile take out what you like, and then zip it up again. We may end up needing something you remove, but we can ask for that specifically.
