Hi team,
We have integrated Nagios xi 5.4.2 with SNOW and use NRDP to create maintenance mode on server/services based on CI name.
However as there was different between CI name and associated host name so maintenance mode is not working. Can you please let us know is it possible to make NRDP case less.
Maintenance is not working on below case:
Case1: Host name define in Nagios as abc where as CI name define as ABC.
Case2: Host name define in Nagios as abc.nagios.com where as CI name define as abc.
We are using the command below to disable host and service.
DISABLE_HOST_CHECK;somehost and DISABLE_HOST_SVC_CHECKS;somehost
Making NRDP case insensetive
Regards,
Sk Abdul Goffar
Nagios Version:Nagios XI 5.4.8
OS:CentOS release 6.5
Sk Abdul Goffar
Re: Making NRDP case insensetive
That functionality doesn't currently exist and would need to be added as a feature request to the Core backend:
I've created a feature request for you here:
You can view the status here:
https://github.com/NagiosEnterprises/na ... issues/373
Let me know if you have any questions.
Thank you
FR - Give the option to do case insensitive matching when submitting commands #373https://github.com/NagiosEnterprises/na ... issues/373
Thank you
