Configure Email NagiosXI
phsita
Post by phsita »
Moderator Edit: This thread has been split from another - https://support.nagios.com/forum/viewto ... =6&t=42205
In the future, please create a new thread and link to the old one instead of adding on.
Hi guys
I am also trying to setup email in Nagios XI.
But I am facing the following error-
SMTP Error: Could not authenticate.
SMTP server error: 5.5.1 Error: authentication not enabled
Here is what my config looks like with which I am getting this error-
Re: Configure Email NagiosXI
Post by dwhitfield »
At this point, it's hard to say *exactly* what you need to do. That said, you need to modify your SMTP setup in some way. Also, I would speak to the admin of relay01 and make sure you are using the right settings. Have you tried TLS or SSL to see if those work? Also, that username and password are for SMTP, not for something on the nagios side, so make sure those are correct.
What version of XI are you running? You can find it in the lower left-hand corner. Usually there's the option to set a debug log, which you don't have.
From the nagios server, can you attach all of the following (if you have them...it's ok if they don't all exist):
/var/log/maillog
/var/log/mail.log
/usr/local/nagiosxi/tmp/phpmailer.log
